Cablefed
20+ Year Contributor
- 209
- 2
- Oct 23, 2002
First off I have spent countless hours searching archives and have gone through most of the possible issues and remedies. So I have done my homework on this issue, I'm just looking for something I may have missed.
I have a 98 GS-T that has 22K original miles. I rebuilt the motor to handle more HP and boost. I got the motor back in the car and am having idle issues. When I press the clutch and rev the car past 3K and let the RPM's fall the car stalls and dies. I also get the same effect on the road. When I press the clutch in to stop at a sign or stop light it dies. When the car is in Neautral I don't get the stalling. I can rev. the motor to what ever I want and it comes back down like it should. The stall only occurs with the clutch pressed in and revs go past 3Kand back down again.
I know for a fact its not the ISC, TPS, and or BISS, trust me I've checked and rechecked these components. I ran this issue through my local guys and one guy says it maybe bad thrust bearings. since RPM's drop a bit at idle when I press the clutch in. They don't drop enough to kill the motor but enough to see the RPM's change by 100 or so when I press the clutch in. I wanted to run this by a bigger audience Here is a list of items I have upgraded on the bottom end.
Eagle Rods
Wiseco Pistons
ARP Main studs
Concept racing dowels on main skirt
New Rod bearings
ACT 2600 Clutch
RRE lightened flywheel
All items have been balanced by a machine shop
On the intake side I have the following:
2G Throttle Body
16G Killer (IHI ball bearing T-bo)
APEX FMIC (All the clamps triple checked for tightness)
Stock Injectors (for now)
S-AFC (set to 0 across the board)
Extrude Honed 2G intake manifold
HKS 264 Intake / 272 Exhaust CAMS
K&N Filter
Aeromotive FPR set at 43 PSI
Greddy BOV (Not venting to the atmosphere)
Tuning Tools include:
All gauges (EGT / Jumptronix/ you name it!)
Pocket Logger
Any help you guys can throw my way would be greatly appreciated.
Marc
Eagle Rods
Wiseco Pistons
ARP Main studs
New Rod bearings
ACT 2600 Clutch
2G Throttle Body
K&N Filter
Pocket Logger
Marc
...clean out ur maf plug in...mine had white gum like material...that should, i dont know exactly how but it does...
