Post-engine rebuild maintenance
Coopens
32
Nov 4, 2010
Denver, Colorado
Ok, I just finished putting my engine back together. Had to replace the head gasket so I replaced all belts, thermostat, water pump, oil pump, all other gaskets, rings, bearings and I think that's all. What else should I replace as far as the engine goes? I was thinking along the lines of spark plugs/wires, distributor cap so on so forth. Any advice would be great!
Spark plugs, wires, air filter, obviously the oil and filter.
If you can find the distributor cap then change that as well.
Oh COOPENS, just so you know what we are laughing at, there is no distributor on your car. You have a coil pack. We're just playing with the newb.
Occasionally I enjoy feeling retarded. This is one of those moments. Thanks for the advice regardless!
