Possible Fuel Issue
Talonfiend
52
May 23, 2008
Pylesville, Maryland
I have a 92 TSi AWD 6/4 5-speed and eprom. Dejon intake, MBC, ISC removed.
The car won't start. The starter just turns the engine. I tried feathering the throttle while starting it but nothing. On the next attempt, it will sputter for a second then just continue to crank. I sprayed carb cleaner in the manifold while a friend started to crank it and it started up. It idled at 600rpm poorly then died. We used the carb cleaner again to get it started. This time we had the throttle wide open and it just stayed at 600rpm for about 10 seconds before slowly increasing. It won't rev past 4500-5500rpm.
At this point I'm thinking its a fuel issue being that it can't idle or fire up on its own. Here's what I've done: compression test(120, 120, 115, 120), changed the throttle body, CAS, fuel pump(walbro 255 low pressure) and injectors. I can't do a boost leak test the car is in the middle of a field and I don't have boost leak tester. I'm kind of lost at the moment, the MPI Relay and ECU could be next to be changed out. So any help is appreciated. Thank you.
Have you checked if voltage is present at the fuel pump during cranking? Does the check engine light flash when you first turn the car to ON?
Well I can hear the pump when I start cranking. Yes the CEL comes on, I just need to find my logger to help me.
