popping noise
ccviper27
May 28, 2005
washington court house, Ohio
I had tre tranny, act 2100lb. plate, act street disc, new transfer case, new front driveaxles recently installed.Still has stock flywheel. I now have a popping noise when I release the clutch in 1st and 2nd. As soon as I release the clutch something pops a couple of times then stops. I also have a wa-wa-wa sound while engine breaking mostly in 2nd and 3rd. Never had this problem until I replaced everything. anything would be helpful. Thanks guys.
Its hard to tell with the information you've given. All i can think of wih the description you gave is motor mounts, trans bolts not tightened all the way, or something with the driveshaft (joints etc.)
Someone with an AWD might be able to better diagnose it better than i can from the description. Good luck :laser:
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
