Popping noise coming from wheel.
GSXspeeddemon
88
Sep 20, 2005
Austin, Texas
I posted a thread about my car shaking on another website.
However i guess the problem has progressed. A couple of days ago when i was driving the car, it started making this popping noise. So i have the car towed home and start taking everything out. I replaced the axle (damaged) and the straight and curved lower control arms. (rubber boot on ball joint non-existant). I take it for a test drive and its still doing the same thing. I drive at 5mph around the parking lot and you can hear this popping noise every second as the tire turns. (It gets louder the faster you go) What could it be.
Well it can be a few things first check and see if you have any loose bolts. What I would do next is check your inner and outer tie rods. stabilizer bar end links gone bad can make a popping noise also. There are alot of variables to figure out.
