Cameron Morison
5+ Year Contributor
- 56
- 49
- Nov 12, 2018
Christchurch,
New Zealand
I came across an issue on the dyno yesterday, immediately after a run the temps would start to climb from the normal low 90's (celsius) up to around 110 if left idling, however if we held the revs up to say 2000 for a minute then the temps hardly rose.
So my theory is here that there is not enough flow around the cylinder block or cylinder head for managing heat soaking through after a run at idle speeds. I have never had this issue on the race track - always have had good temps but I've recently just replaced a head gasket (if that has any chance of changing things at all)
Possible solutions Ive thought of so far are:
- electric water pump
- electric booster water pump (on demand, run only at low RPM when coolant temp is high)
- change pulley ratio for water pump (Increased chance of cavitation at high RPM)
- change water pump to better design impeller (Im pretty sure its got a open vane impeller currently, it was aftermarket replacement 4 years ago)
- Increase Rad cap pressure (currently seems to vent at 10psi based on the logs)
My system isn't quite stock:
- Twin pass 300x600x76mm cross flow radiator (more drag than an OEM one)
- Single drive belt for alternator and water pump, drives off the outer crank pulley and onto what I think is the larger of the two pulleys attaching to the WP.
- Has a pressurised expansion tank rather than a recovery bottle.
Any suggestions or DSM wisdom that can be offered?
