Poly Master bushing sets come with rear Knuckle bushings?
95EclipseGST
406
Mar 1, 2002
Kansas City, Missouri
I need my rear knuckle bushings replaced very badly and am wondering if i buy one of these master bushing sets "black energy suspension master kit" does this come with the rear knuckle bushings? Thanks for the help.
Bought mine from here: http://cgi.ebay.com/Rear-Control-Ar...5QQihZ015QQcategoryZ88433QQrdZ1QQcmdZViewItem.
Came with the entire rear end bushings (including the upper knuckle bushings), if you need both front and rear then you'll have to buy the whole kit which is more expensive.
Look at my thread so you can see what the rear kit comes with and also for info on installation from the other members.
http://www.dsmtuners.com/forums/showthread.php?t=236736
Part #'s from ES:
Rear End Control Arm Bushing Set from ES : 5.3119 (which is what I got)
Front End Control Arm Bushing Set from ES: 5.3118
HYPER-FLEX SYSTEM Complete Master Bushing Set : 5.18107
(Includes: front and rear control arm bushings, front and rear shock bushings, transmission shifter stabilizer bushings (manual transmission only).
"HYPER-FLEX SYSTEM Complete Master Bushing Set : 5.18107
(Includes: front and rear control arm bushings, front and rear shock bushings, transmission shifter stabilizer bushings (manual transmission only)"
SO this does include Knuckle bushings? Is that the same thing as front and rear control arm bushings? Sorry if thats a dumb question, just need clarification. Also is the master bushing set, all of the bushings i would possibly need for suspension? I thought i had seen kits with more pieces.
The rear knuckle has three bushings: an upper, a lower, and one for the trailing arm. All are in the master set, as well as the set for just the (entire) rear.
- Jtoby
