plug pig tails
psychoticj
Apr 21, 2010
Rockford, Illinois
I have some broken plugs that are bothering me and was wandering if anyone knew where or if they are available some pigtails or just new plugs. I would really rather not buy a whole new wiring harness for a couple bad plugs. the main one is the tps sensor plug it falls off sometimes. I know you can plugs from here Automotive Connectors and a few other sites but cant figure out witch one is witch if anyone has any idea of manufacturer or p/n that would help alot. also need the cps plug. Thanks for any help.
:edit: also found this place with good info and a lot of vendors selling plugs http://www.rowand.net/shop/tech/AutomotiveElectricalConnectors.htm
If you have a you pull it junk yard near by, its your best bet for connectors. Most mitsu cars use the same connectors.
You have to do a lot of research to match up part numbers to plugs. And most of the time you are facing minimum orders(1000 pieces), or parts that are not manufactured anymore or were specially made for mitsu.
Another issue is price. In small quantities plugs are expensive.
My last trip to the junk yard I got a bag full of ecu connectors, that they let me have for free, if I bought the connectors and pins new they would have cost over $200.
A good site for finding Mitsu connector part numbers -> MITSUBISHI CABLE AMERICA, INC.
