Please help pick cams and also review this setup
Kevin TSI
136
Jan 11, 2007
Muncy, Pennsylvania
Hi, Maybe some of you have seen my build blog for the 1991 gsx my friend and I am building.
Here is a rundown of the build so far. Lots of stuff has been purchased but some stuff hasn't. Some of it is not important for this thread but the list is copied and pasted so bare with me. Nonetheless we need help selecting the appropriate cams for our set up. Also any input on the set-up itself would be nice.
ENGINE:
Eagle rods
stock crank
stock bore wiseco 8.3:1 pistons
BS removed
All ARP
HEAD:
Stock with some minor porting
BC springs and retainers
ARP studs
TURBO:
HX-40 6 blade
.70 T3 hotside
Topmount T3 manifold
full 3.5" downpipe bumper side exit
Tial 44mm wastegate
INTAKE/ FUEL
17x17x9 fuel cell
Full -8 AN braided fuel system
JMF drag mani. With stock TB
HKS knockoff fuel rail
1000cc PTE injectors
Tial 50mm bov
2.5" short route piping
34x10.5x3.5 short route intercooler
MAFT
CHASSIS/ DRIVETRAIN/ ETC.
Solid filled driveshaft bearings
All prothane chassis bushings/ motor mounts
ACT Xtreme clutch 2900+
Stock flywheel
Stock tranny:ohdamn: At least it doesn't grind!
Stock 3 bolt rear:cry:
GR2 struts with Eibach pro springs
15x6.5 Rota slipstreams
26x9.5x15 Hoosier QTP
1gb big brakes
COOLING
Aluminum civic half rad
All coolant lines have been deleted except the radiator ones
12" slim fan
OTHER CRAP
Chipped eprom
4500rps stutterbox
8.5k redline
No Power steering
No AC
Car has 8pt cage, gutted with about 2750 weight. Will be lighter soon. Keep up on the build blog!:hellyeah: Hoping for 30+psi and the car will be run on 110 octane cam2 race fuel. We are really hoping for lower 10's in this thing but we would be happy with anything in the 10 second range honestly to start out with.
My real question is what size cams should we go with in this thing? Also other than the tranny and rear do you see any weak points in this set-up? They aren't in the budget this year but will be taken care of next year. Hopefully DSMlink also. We are going to push the tranny and rear as far as we can until then. Do you think our goals are achievable? Any input or advice?
dont use a "chipped ecu" go straight to a dsmlink or an aem...I would deffently beef the trans up before you did anything. they are the weakleast link. Also for cams i would go with FFWD dks3's there 280 duration
i say go with the bc 272 and as for the setup i think its great for a ten seconds. as for the slicks you are using i dont how long that drivetrain is going to hold up but would definitly be slipping the clutch off the line
Ok a little update. Going with DSMlink now and also got a 4 bolt rear. Hoping the tranny can take one season beating before we go with a built one.
Good thing on the rear. I have broken two 3 bolt rears on just a 16g. Granted it is making over 400lb/tq but still they are weak.
That stock spider gear diff is not going to cut it. If you guys put some sticky tires on there and start launching it then its going to brake fast. My brothers 16g car destroyed his stock tranny just going WOT in 4th gear!! But with the stutter box at 4500rpms you wont even get a launch, more of a bog and a slow take off. Thats even too low for my 16g car to launch good.
On the cams I would go with something more aggressive than the BC 272's. I would look into Kelford 272's. They are very aggressive and dont loose as much down low as some other cams in there range. Also if you havnt bought the valve springs I would look into some beehive springs. They are a lot safer for high rpms and big cams. VR Speed Factory - EVO, DSM & WRX Performance Parts - GSC - GSC Power-Division 4G63T Beehive Single Spring Set : 1G & 2G DSM / EVO 8 & 9 / 4
Thanks for the input! Much appreciated. So maybe we should hold off for an extra season and just have a tranny built.:thumb:
Id like to see a dyno slip on that 400lb/tq with a 16g that means your making over 500hp.
