Please help me
eclipse001
165
Sep 25, 2009
racine, Wisconsin
So over the weekend I dropped the trannie and put an ACT 2100 clutch kit along with an ACT lightweight flywheel clutch fork and pivot ball. Anyways got it all put together today and I went to drive it turns out I don't have a 1st or 2nd gear I have to start in 3rd. After it gets going it shifts into 4th and 5th fine. Anyone have any idea on why I don't have a 1st or 2nd gear? My shifter feels like a short shifter but it isn't 3rd gear is where 1st should be can someone please help me?
First off, make sure that you have your clutch shifter cables properly installed and mounted. Next, adjust your clutch master cylinder and bleed the clutch properly. You have a new clutch, it needs adjustment. It sounds like you are having clutch disengagement issues or overengagement issues.
