bigredram87
- 0
- Aug 25, 2007
medina,
Ohio
Ok I have to have this car up and running by tuesday to commute to school and I have been fighting with this car for a month now!... I have narrowed it down from what the car is doing to the actually parts malfunctoning so here it is.... OK first off when I ground out the timing probe and pin 10 i cannot gett the biss screw to drop down to a smooth 750. it either idles at liek 15 or it stalls...It actually is quite random one sec it will be a 1500 smotth then it may drop to 500. Yes i have read about idle stutter and I have replaced everything. DOES this mean maybe my Tb may need to be replaced since it is a 90 1 piece? or is there something else that would cause this... the other issue is I cannot set the timing because i cannot get a steady IDLE. and lastly in the boost leak category I cannot give a proper boost leak check because it all leaks out of my crankcase BREATHER.... I just replaced the pcv and it is still doing this.. I bought a pcv from autozone and I checked it by hooking up compressor to it at 15 psi and it does slowly leak through... does this mean it is also bad? Can you please help ME ASAP I really need to figure this out! THanks so much
