please help: carrier bearing installation?
gen1gsx
Feb 19, 2004
Billings, Montana
i got new center bearings for the driveshaft don't know exactly how to change them. anyone ever installed new carrier bearings? if so how hard is to do and how long of a job is it?
thanks for any help
If I were going to bite into that job I would go ahead & replace EVERY Universal Joint while you have it torn down - Might as well plan on changing Transfer Case Fluid being you are sure to lose some anyway - Maybe the Rear Transfer Case Seak if you had some Driveshaft wobble - Mark where the Old Bearings were for rough alignment purposes - It 's certainly an all day job - You need 4 good Jackstands & Safety Glasses too - be careful under there. :thumb:
