Please help breaking up at high rpms
John95GST
Jun 4, 2012
hillsville, Pennsylvania
ok 95 gst was running great from what was told went to look at it and injector 2 was out so he got stock injectors found out that 660 were in it befor now when i went to drive it it pulls hard till about 5500 to 6000 and breaks up? shoudl i do a walbro 255 will that help? its runnin 14psi or should i get different injectors or could it be something else thanks for your time
Ok I bought v3 my break up at high rpm is gone but no I get random
Misfires at low rpm like will run fun then bam it will start missing is what it feels like if I shut it off then back on its fine again now what did I do I had v3 tuned with stock injectors and stock mass sensor so now I'm puzzled again also did new plugs since it was running lean befor
An idle log will work, and let it run long enough to catch in the act! If it doesn't that's fine. A log is worth a thousand words!!!
Does your 2g have a 6 bolt swap by chance?
What plugs did you get and what gap are you running?
im running a 1g cas or the adjustable timeing and forgot to uncheck missfire detection it hasnt done it yet since
