Please Help Anyone !!!!!!
eddieq19
Jan 23, 2006
San Pierre, Indiana
Here the Problem
First Off This Happen 3 Times Already in a month
The problem is while driving my car it starts losing power after a while it loses power to everything my lights dim (real bad) radio turns off and eventually the whole cars dies and wont start back up unless i push start it now the first time thought it was my battery change that nope not battery ok well the it the alternator also no but when i replace the belt it works fine well also so far when i took off the belt i noticed rubber shaving all over the alternator and after looking over the belt it real in bad shape the the riges are chip and some are bald i want to know what can make this happen what can be eating up my belt thxs ahead :dsm:
The tension in your alternator belt is not set properly/tight enough. Adjust the bolt in the tensioner to draw the belt tighter.
Reformat your post with some punctuation, check the spelling, use a decriptive title and repost it. If you can't be bothered to communcate clearly, we won't bother to help you.
