please help 14b oil leak from clamp
FSTRDNU
150
Jun 6, 2005
parma, Ohio
when i put my turbo back on my car, it leaks oil, from in between the housing of the turbo now, is ther a special way you have to put that clamp on, because oil is escaping from it, please tell me what to do, so it will stop leaking,it dont think tightening it anymore would do anything
If it's leaking out of the V-clamp between the center cartridge and turbine housing, most likely it's from the turbo seal on the hot side. Make sure it's not dripping from the oil feed line. Good luck.
there wasnt a seal between the two housings, just a pin that a hole lined up in, and a clamp
The seal isn't between the housing and the center, the seal is between the turbine and the center.
