Please check out my first logs
Nofear20
345
Aug 9, 2007
Yakima, Washington
Both pulls were done in 3rd gear to redline. All mods are in my profile. Doing logs becuase my car is not pulling as hard as I think it should be, and was told to have my logs checked. Thanks
I would say it actually looks pretty good. Timing drops a little low when boost hits and you may have a little knock there but after that timing rises how it should and hits a good 19*.
How low is low? My logs go all the way down to 4* around 3500 RPM and then slowly climb up to ~17* at 6700RPM (it starts pulling timing right around 7K).
4* timing right at boost is real low. I would say you have some knock at timing pull when boost hits. I cant quite remember but I think a 2g timing should be around 10-12* at lowest, but Im not 100% positive, I never work on 2g's much.
Is it correct to assume that the lower the timing, the more power, but also more knock? Or am I totally off?
Would this be the same for a 2g with a 6 bolt swap?
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
