Check my LOGS
Crazyjoker77
159
Oct 9, 2004
Medicine Hat, AB, Canada
okay sorry for the poor sample rate working on gettin that up anyway heres my log rs49T@18psi fic 650s SAFC and MAF-T plus misc mods in profile. relize im probably running pretty rich as i have it to zero out on the maft and plus 6% on the safc (theretocaly 6% rich)
time.. rpm.. timing thr.. 02v
1.68 3116.0 29.0 63.26 0.04 0.0
2.53 3352.0 28.0 96.66 0.06 0.0
3.35 3668.0 25.0 96.66 0.78 0.0
4.18 4052.0 17.0 96.66 0.94 0.0
5.02 4500.0 9.0 96.66 0.98 0.0
5.86 4932.0 9.0 96.66 0.98 0.0
6.7 5340.0 8.0 96.66 0.98 0.0
7.5 5748.0 8.0 96.66 0.98 0.0
8.36 6152.0 11.0 96.66 0.96 0.0
9.19 6144.0 12.0 96.66 0.96 0.0
you should be getting 100 percent onthe throttle . You need to check and see if your linkage needs adjusted!
Are you saying the MAF-T is set for the stock 450's and you have the SAFC at +6 %? Or is the MAF-T set for 650's?
sorry guess i should of specified the maft is set for 660's according to the chart that came with it. then i have +6% fuel on the safc (as in the maft is taking out to much and i added it with the safc) also i get 100% throttle reading on the safc and really anything above 92% should be fine for tuning purposes. also if im cruising at 3500rpm at mid throttle i will sometimes get a random missfire.
okay heres a new log with a much better sample rate
stamp rpm.. tim.. thr.. 02v..
1.0 2948.0 29.0 96.66 0.04 0.0
1.5 3080.0 28.0 96.66 0.04 0.0
2.0 3204.0 27.0 96.66 0.06 0.0
2.5 3360.0 26.0 96.66 0.14 0.0
2.99 3524.0 23.0 96.66 0.8 0.0
3.48 3744.0 20.0 96.66 0.9 0.0
3.98 3988.0 17.0 96.66 0.92 0.0
4.48 4232.0 13.0 96.66 0.94 0.0
4.98 4468.0 13.0 96.66 0.96 0.0
5.48 4720.0 14.0 96.66 0.96 0.0
5.98 4960.0 13.0 96.66 0.96 0.0
6.47 5208.0 13.0 96.66 0.98 0.0
6.97 5428.0 13.0 96.66 0.98 0.0
7.47 5712.0 14.0 96.66 0.98 0.0
7.97 5932.0 15.0 96.66 0.96 0.0
8.46 6160.0 12.0 96.66 0.92 0.0
8.96 5348.0 5.0 1.96 0.7 0.0
9.46 4436.0 33.0 14.54 0.58 0.0
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
  • For sale 1g Kiggly Racing 1G 7 Bolt Flex Plate
    Kiggly Racing 1G 7 Bolt Flex Plate $85 + shipping & paypal fees* these are $175 onlineYou...
  • For sale SBC Organic Clutch Disk
    Brand new organic material disc came from the SBC Stage 3 street K05048-SS-O CLUTCH kit, but I...
    • Mahreeoh17
