One of my logs help
90mitsu3clipse
114
May 24, 2006
waco, Texas
This was from 1st gear through 4th????
RPM TPS KNCK TIMA INJPms INJD% O2-R
2437 17.5 0 35 2.81 5.4 .27v
2531 19.1 0 35 3.07 6.2 .68
2656 22.2 0 34 3.83 7.8 .13
2875 23.4 0 33 3.83 8.5 .68
3093 25.3 0 33 4.60 11.7 .46
3406 28.5 0 33 5.37 14.8 .66
3937 82.4 0 30 10.75 35.1 .00
4875 99.6 0 24 17.91 72.6 .72
6187 99.6 0 19 17.66 90.6 .68
6656 82.8 0 20 8.95 49.2 .68
5125 9.7 0 31 8.44 35.9 .60
4125 99.6 0 29 15.61 53.1 .72
4656 99.6 0 18 17.15 66.4 .70
5000 99.6 0 19 17.91 74.2 .70
5312 99.6 0 18 17.66 78.1 .70
5656 99.6 0 20 17.40 82.0 .70
6000 99.6 0 21 17.40 86.7 .70
6187 99.6 0 22 16.89 86.7 .70
6375 84.7 0 21 12.03 63.2 .70
5468 22.2 0 21 9.72 43.7 .54
4531 99.6 1 27 16.89 63.2 .72
4625 99.6 0 19 16.63 64.0 .70
4843 99.6 0 19 17.15 68.7 .72
5031 99.6 0 18 17.40 72.6 .70
5187 99.6 1 18 17.15 74.2 .70
5312 99.6 0 20 17.15 75.7 .70
5437 99.6 0 20 17.15 77.3 .70
5531 99.6 0 21 16.89 77.3 .70
5781 99.6 0 21 17.15 82.0 .70
5843 99.6 0 22 16.89 82.0 .72
5875 99.6 0 22 16.89 82.8 .72
6125 99.6 0 22 16.63 84.3 .72
6156 99.6 0 21 16.63 85.1 .72
6156 99.6 0 21 16.38 83.5 .72
6375 99.6 0 20 16.63 88.2 .72
6468 99.6 0 21 16.38 88.2 .72
6406 48.8 0 19 3.07 16.4 .72
5656 78.9 0 45 11.77 55.4 .70
4781 99.6 0 25 17.91 71.0 .76
4875 99.6 0 18 16.38 66.4 .74
5031 99.6 0 18 16.63 69.5 .74
4937 99.6 0 18 17.15 70.3 .74
5093 99.6 0 18 16.89 71.0 .74
5156 99.6 0 18 16.89 72.6 .74
5156 99.6 0 19 16.89 72.6 .74
5281 99.6 0 19 16.89 74.2 .74
5406 65.2 1 20 15.87 71.0 .74
When timing starts being pulled, you need to add some fuel. So if your timing is going on a steady upward trend (like it's supposed to) like 14-14.5-15-15.5-16 then suddenly drops back to 14.5, it means your ECU is pulling timing. Add some fuel. The timing usualy gets pulled up top in the RPM range.
Go ahead and replace it for peace of mind. The fuel is not bad. Your log is very good for a factory setup. Don't worry too much right now about fuel control unless you have enough money. But don't go turning up the boost without the proper fuel mods/control. Good luck!
I'd like to point out a couple things. Timing gets pulled for more reasons than not enough fuel. Coolant temp for instance, will drop the timing. The only time you need to add fuel is if you are seeing lean knock, which you look to be clear of.
Redo your logs with just RPM, knock and timing so there are more samples per second.
I don't see any reason to add fuel anywhere, but I will question whether your base timing is set properly. When boost kicks in, your timing should be mid teens at best. See if you are really at 5* BTDC at idle.
When I tried to set the timing at 5 btdc, it acted as if it were going to die out. Can I set the timing with the Data logger plugged in? And can I go by what it says? If so, it's at 8 or 9 degrees. I cant get it to go to a stedy 5 degrees..
Replace what? I have some money...
Replace your o2 sensor. If you've never replaced it, it's probably due up for one. As far as setting timing, you need to use a timing light. Set it at 5* BTDC as a base, and do timing from there.
What if it will not stay idling when I am trying to set the timing.. Cause when I ground the tach sensor, it really changes the way the car idles, almost as if it has a set of lopie cams.
