PLEASE can I reuse this?
wickedz
736
5
Dec 12, 2009
Madison, Wisconsin
Yeah I should have removed it before installing motor. The oil tube stuck itself a good one in my radiator. Never used, brand new. I know they are not that expensive but I would like to reuse it if I can. Please be honest tuners :thumb:
As long as it doesn't leak, I'd say yes.
Make sure to test it first though.
how do I test it? Just fill with water?
IM SUCH AND IDIOT for not removing it
You should pressure test it, I'm not really sure what our system runs at though. Maybe somewhere between 8-14psi?
Hopefully someone else will chime in on it.
just fill it with water and watch for leaks. If no leaks then I'd toss it in and roll with it. But I would also be putting some cash to the side for a new one anyways. Bent fins can cause problems with airflow through the radiator and overheating problems. Costly mistake, but we learn from our errors.
i agree pressure test it/check if it leaks. If it dont leak it may not hold pressure very long and ull over heat possibly blow ## HG.
It will leak, sometimes they can be fixed if they have small holes but that core is seriously mashed up.... Probably will be cheaper just to get another...
while doing a leak test is obvious to determine if it works, the metal passage in the center damage is completely GONE!!!!! obviously this will leak, but if you do install understand that u must constantly check for leaks!!! by that im serious like a heart attack, because if your down the free way and it decides to burst and u dont notice it, ..... kiss your engine goodbye!!! so think about the risk factor, vs spending 150 and being in the safe side. just my 0.0000002 of a cent
BUT THIS RADIATOR IS UNSERVICEABLE,
