Can i reuse the Headstuds?
Sicotic
278
May 26, 2009
fairbanks, Alaska
I heard from a feew people that alot of cars headstuds you cant reuse bc it has been torqued is this true? Do i need a new set also i have a 2g head going on 1g block the 2g has ARP headstuds i cant use them right?
i know you cant reuse the stock head studs. but ive been told you can reuse arp head studs. i even bought a used set.
nope cant used them 6 blot studs are different and so is a 1g and 2g head.if u have stock studs u can reuse them but your running a hight risk of a blown headgasket.get 6 bolt arps 80 bucks and your set
speeling owned. Dont post what you don't know for all you really know he might actually have a 7 bolt so he can just put it right on.
i heard alot of things about 1g and 2g heads, ive been tol i need to drill the holes out to fit a 1g block, then ive read that it doesnt have to and theres alot of people that dont. any thoughts
arp's can be reused, oem Mitsubishi's can not be.. so i would just invest in a quality head stud
Actually, the 1g 6 bolt head bolts can be reused. None of the 7bolts are reusable.
hmmm well thank for letting me know Keith.. looks like i need to read a bit more before i post info LOL thanks for straightening him/me out... :)
Actually, the 1g 6 bolt head bolts can be reused. None of the 7bolts are reusable.;)
guys this per the mitsu service manual... 6-bolt head studs can be reused as long as they are within spec for stretch, 7-bolt head studs are i believe an 11mm smaller than the 12mm 6-bolt head studs and CANNOT be reused. I have stock 110,000 mile 6-bolt head studs that have been reused with a MLS headgasket and i can get away with 32Psi of boost:rocks:
