Pit 9700 Electronic Boost Controller
blazeonenet
Apr 16, 2008
Tacoma, Washington
The Performance Import Trends 9700 boost controller is a nice unit, overall similiar to alot of other ebc's out there. It does feature integrated turbo timer (with auto and manual timer settings), and can trigger 2 additional circuits (nos etc). And has a built in pressure sensor so functions as an accurate gauge.
Installation: Pretty straight forward for the main boost control unit and gauge, the additional features requires wiring in spdt relays but are triggered by the control unit from there respective harnesses.
For the gauge/monitor vac line i plummed in right off of the intake manifold with a y adapter on the line that hits the fpr/sensor. I ran this line through the steering boot at the same time running the two wires for the boost control solenoid from the control unit.
For the boost control solenoid, I installed the included fittings on ports 2 and 3, leaving 1 open as my setup is a single t25 turbo w/ internal wastegate. I mounted the unit near the stock BCS but replaced the lines and capped off the stock BCS leaving its harness plugged in (as not to set the MIL light). Attached the two wires from the new boost control solenoid to the leads I had ran out into the engine compartment earlier.
For settings this unit uses Start Boost (Psi), LoGain (%), HiGain (%), LoBoost (Psi), HiBoost (Psi), Warn (Psi), and Limit (%). Should you pass warn boost the unit flashes, display turns to red and cuts out the boost based on the % set for Limit.
My Initial Settings (Lo):
Start Boost: 7PSI
Gain: 20%
Low Boost: 10PSI
Warn: 15.5PSI
Limit: 85%
Drive tuning now to get optimal numbers, keeping in mind im running a stock T25, I do have air intake and exhaust however.
Currently set to purple, the blue looks good also I think.
The new boost control solenoid.
I'm still fine tuning but it works great I like it, and for me more of the tuning is in psi instead of % (compared to profec), which makes it a little easier to dial in. I gotta see when I can get on the AWD Dyno, so I can check some numbers with the wideband.
  • For sale 1g 90 Oil Cooler
    90 OEM oil cooler with custom lines. Takes 18x1.50 mm fittings at the housing. Fits in a...
  • Wanted 2g 2G FWD Fuel Filler Rubber Hose
    Decent condition FWD fuel filler hose.
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
