Piston question
kxfreak125
73
Dec 21, 2008
Livingston Mano, New York
I'm currently looking to purchase a g4cs hybrid shortblock. The motor spun a main bearing with no damage to the crank or journals. Upon dissasembly my friend and I noticed all the pistons have some scratches below the ringlands I'm just wondering if they are complete scrap or might be reusable. Pistons are Ross part # 75029 f2 with eagle rods. I attached some pics let me know your thoughts guys thanks
The piston shown is the worst of them all
Personally I would recommend you replace them and triple check your piston to wall clearance and your main and rod bearings. Doing it right the first time will payoff in the end.
I concur with doing it right the first time. How's the cylinder walls look? Piston looks pretty beat up.
I purchased some used ones that looked like yours and got them checked. The mechanist asked me if I was joking and laughed at me. I would really get some new ones. Extremepsi has wisecos on sale for 44x.xx right now with rings pins and everything. Do it right the first time my friend that way you know what you have and a little piece of mind is always a plus in books.
Anthony B.
JUNK and there are custom. ross part numbers start with 9 for 4G63 stuff and 7 for custom as told by Ross
i would run arias pistons but if you want to safe some money just buy wiseco.
part number K564M87 for a 20 over piston
Or call here http://magnusmotorsports.com/products/engines-and-internals/magnus-4g63-pistons/#.UdummvmTjgk
ask for Lio and tell Mr whitehorse sent you and yes both are real people
Specs on what you need
Bore 87mm / 3.425"
Stroke 100mm / 3.937"
Rod Length 150mm / 5.906"
Compression Height
35mm / 1.378"
Dish Volume -21cc Dish
Compression Ratio 8.5:1 - 8.7:1
Wrist Pin Diameter 21mm / .827"
Included Wrist Pins .200" Wall
Ring Stack 1.0mm x 1.2mm x 2.8mm
Hope this helps
Thanks for all the help guys I figured they were junk. The owner says he would get some piston slap during warm-up which most likely caused this. I guess the custom ross pistons will make nice papersweights.
Bore 87mm / 3.425"
Compression Height
35mm / 1.378"
Hope this helps
Thanks for the specs man I was actually looking at the Magnus pistons last night and that's probably what ill go with. Their pricey but I'm sure there a quality part if there like anything else that they sell. I have a Magnus intake manifold and I love it. I just wanna make sure I'm not jumping in too over my head I've always ran stock motors and had good luck but always ran small turbos. I wanna go to a big turbo now and make some real power.
