Part name??
n00btalon
197
Aug 13, 2005
lebanon, Pennsylvania
I need to know what to look up for... I need to replace the right front half-shaft / cv axle on my 1g awd ... the guy that does work for me said he can't get the hub off its frozen up so I should replace it... what is that called?? i find the rear hubs easily... can't find the front ones, its it something else? all one piece? or what... confused :confused:
any ideas?
It sounds like he is describing the axle being stuck in the hub. Let your guy know heat and a big hammer, If that does not work then good luck. If this is the case I personally took off the hub and removed the axle together. Then i proceeded to slam the axle nut end on the ground it broke free after a while. Good luck I hope I helped a bit.
Darren
