Part 2 of my idle problem a couple pics included (ISC,BISS)
jarredsyxx
Mar 16, 2006
Connersville, Indiana
still idling at a solid 3 grand :)
I found the BISS is somewhere in the world...but not in the throttle body...I guess Ill order one from machv ... thats one thing I found...definately isnt helping matters any
[/url][/IMG]
next I wonder about the ISC I didnt take it off...and upon consulting my manual ...I noticed that their car where it hooks up to the trottle cable/linkage the acuator Im guessing ...it had a two wire plug...this is the one on mine
[/url][/IMG]
mine has only one prong and someone has kinda hard wired it in...is this right? ...just outta curiosity I took it off...and started it.... didnt throw a CEL ... and stayed the same...maybe Im onto something...I just cant seem to find a picture to verify it...
thank you for looking
The wire is not the ISC. That is a switch that lets the ECU know that the TB is fully closed.
The second picture has your ISC at the very bottom right hand corner. Here is a 10 sec chop to show you.
do you think I should probably clean it...while Im down waiting on the BISS... I mean its not gonna hurt right...all it could do was maybe help
You don't need to clean the ISC motor, but you could clean the passages it regulates. If the motor is just idleing high it is becasue you are missing the BISS. If it is surging that would be the ISC.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
