'paint it any color you want as long as its black...'
Turbo442
67
Oct 21, 2004
Portland, Oregon
I beleive Henry Ford once said...'paint it any color you want as long as its black'
Well actually I powder coated everything semi gloss black. I got tired of the rice look and miss-matched colors. I do need to pick up some black silicone 2.5" couplers...the blue isint cutting it. Never gave a $hit about my engine bay until recently, now I am trying to clean it up a bit. The semi-gloss kind of gives it OEM look.
Just installed an EVO head and exhaust manifold gasket, ARP Head bolts. Had the head planed and a 3 angle valve grind. Installing a catch can and moving my fuel pressure gauge inside so I can see whats happening at WOT. Re-built my TB with new O-rings will pressure test to 25 psi. Welded a 2.5" mandrel bend onto the end of an Injen intake. All new injector seals and o-rings.
We will see how she runs this time.
90 AWD 5sp, 20G, Tial 35mm, 9.5x28x2.8 FMIC with 2 1/2" piping, 550's, 2G mas, 2G exhaust manifold and O2, full 2.5" exhaust with TP, 3000 VR4 pump, SAFC, 2.5" intake pipe, 2G pistons, new style lifters.
I removed the motor mount to let the motor 'float' with the wheel hop.
He must have got those clear mani-turbo bolts with that motor mount.. Either way, looks good.
-Dallas J
Hey quit flaming the guy because he took some pics before he finished the install, probably got excited about how awesome it looked. I think it looks beautiful Turbo442 :thumb: , very clean. How much did it cost to have all of the powdercoating done?
Yeah it does look nice! What are the letterings on the cover, white or polished? I may "copy" you but I'm across the country in central New York so we won't be next to each other at Wal-mart, mine's Red also! mark
I picked up a powder coating kit from harbour freight for like $60.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42802
Just buy a cheap oven from a used appliance place for like $50, dont use one you cook with. You can get all kinds of powders now, even chrome and flourescencs, check on E-bay for good deals. Eastwood also sells stuff, but the harbour freight kit works just as well.
I just used a rubber sanding block with some 80 grit and then 320 grit and took it down to the aluminum.
You guys better not be flaming me...
I don't think anyone is flaming. Just messing with you. All kidding aside, that's some nice work. How much would you charge if I sent you some of my $hit?
You could get all that powdercoated at a local shop for like $100. Much easier to do and work it to me.
BTW, Looks good that's what I plan to do when I get back home.
I went the same route. When I ran through the smog check with all stock accessories last year TWO guys about broke their necks checking it out. Maybe they had never seen one before but I took the hint. So as I built the car the motto was 'black is beutifull' Now I see that two DSMers got their cars stolen here in the same week. Believe me the sleeper look rules.
Untill you find black silicon couplers, use wide electritions tape.
