bov not as loud as before
viperbenz1
249
3
Dec 28, 2008
boston, Massachusetts
hello everyone,
ok i just went from internal to external wastgate and now its not as loud as before . any ideas guys? thanks
So nothing was done to the BOV? Maybe your WG is just louder? Same PSI?
yeah same psi, still not as loud, also if i run the wastegate pip back to the down pip, i wont hit boost creep right? open wastegate is just way too loud for me:coy:
External wastegate is probably regulating your boost better so you aren't making as many psi and therefore the BOV won't be as loud. Other than that I would suspect a boost leak somewhere.
hey man if you do run the external wastegate back into the downpipe make sure you put in after the bend in the down pipe prob about 5 inches past it. thatll stop the boost creep. hopefully that made since
thanks alot man
