Tial 44 as BOV?
tenn-gsx
1,269
25
Apr 25, 2006
Fort Worth, Texas
After reading about the Dodge Garage mod on a 1G BOV I have been toying with the idea of using a Tial44 as a BOV.:sneaky: The vent port on a tial can be used as the Boost/Vacume port for BOV operation couldnt it? I mean If you attach the line to the top instead of the side It will hold the W/G shut rather than opening it. (I know Because I inadvertantly boosted to 36 PSI doing this on my W/G:banghead:) Thought and opinions on this?
it will boost leak for sure. doesnt have a rubber valve seal like reg bovs have
I'm sure if you were really determined you could modify it to work but I doubt that would be cost effective.
There are some 1500+hp race cars which use wastegates as "spool up" valves so it definitely can be done...how does it work? I have no idea how.
One example was Justin Humphrey's 7 sec Lexus GS300.
Its not used as a bov. As olmytsi said, its a "spool up" valve". What it does is stays open and it allows the turbo to spin as fast as it can and when the CO2 goes it closes the wastegate and all the boost comes in all at once and allows you to leave hard. You have to have a CO2 system to open and close the wastegate. Its only intended for track only cars.
