420A P0104 code help
bboyroxas
65
Sep 5, 2012
gallardo, Tennessee
I was driving and the light came on then went away the next day then back again later what does this p0104 01/01 02/02 code mean on my 98 Eclipse RS any ideas? I have a cold air intake
CLean the IAT sensor and make sure to check the connector to make sure the wire connections are good. After that re-set the battery make sure to apply the brake to get all the power out of the system. Once that has been done re fire it up and see what she does. If the problem persists i would change the IAT there is no MAF. Also, check the MAP sesnor on the intake.
It should of been in your factory air filter pipe. When you install a aftermarket cold air intake you have to swap that sensor off the old stock pipe and into the new pipe. Intake air temp sensor should be installed in the air filter pipe with a nice tight fitting rubber groment right befor your throttle body.
Maybe your is missing that sensor? Do you have a wiring plug in around the pipe that's just hangin out not plugged in doin anything? If so find the sensor and put it in the pipe.
Also, on the intake mannifold you should find another sensor. A mannifold absolute pressure sensor. Make sure that wire plug-in also has a nice connection.
I never knew about it and when I bought the car he did not have an intake set up at all so I bought a cold air before we even drive it because it had been sitting
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
  • For sale 2g 1997 Mitsubishi Motors Eclipse Service Manuals
    1997 Mitsubishi Motors Service Manuals $50 for the pair + shipping & paypal fees* I priced...
