36mafia
- 34
- 0
- Feb 23, 2008
hazel park,
Michigan
Alright, ive read plenty on threads and done many different things, and still i have an oil leak in the timing area. Noones threads have helped me solve my oil leak yet. And i hope ill get some help if i post what my problem is. So far ive put rtv on every bolt i could think of. All new gaskets and seals (cams, oil pump seals, oil filter housing gasket, etc...). I still have the balance shaft. I even went through 2 sets of gaskets and seals on the oil pump assembly alone to double check. Torqued everything down. I took off the cover and ran the car up and down the driveway a few times, and oil WASNT leaking. If i let it idle, or rev it up while in neutral, theres no oil leaking either. The oil will ONLY leak after i drive the car. It makes it impossible to spot where its coming from because it splashes over everything...even with the dye. The only thing i forsure know, is that the oil runs down the oil filter housing when it leaks. Any help would be much appreciated.
. ill have to check that.
