out of fuel?
anchew02
59
May 17, 2011
maricopa, Arizona
I logged my car last night and this is wahat i found. i had 28knk, 19.ms injector pulse,91.3 %duty cycle at like 5500, an 02 .046v im outta fuel right? This was a 3rd gear pull to 5500 and then let off.
If you can, put some copper tubing on your regulator and run your gage in front of the wind shield so you can see it when your in boost. if the pressure goes up one to one with boost your good. if not, then you'll have to dig deeper to solve the problem .
im really thinking about getting ecm link... just when i get the money for it they raised the price :0( i guess i could get ecmlink light and my wideband. then ill have to search for a 90 eprom ecu
How much boost are you running? Do you have a real boost gauge? IIRC 90% IDC's is about where i was on my old 16g at around 15psi with the stock injectors. Is you walbro rewired? Have you boost leak tested lately? A boost leak will throw off your IDC's. Your probly knocking cause the 16g is notorious for boost creeping with the full 3" exhaust.
