Out of curiosity..
I'd think that you wouldn't have a problem if your boost is still the same as when you passed it before (or as long as your current boost keeps you under the legal amount. I'm not sure what it is, because they don't test smog around here.)
i always heard it to be illegal to put an engine in your car that was from a car older than yours. I.E. if you put say a 91 6bolt in a 92, even if the 91 had less miles, its illegal. or putting a 6 bolt into a 2g which is a 7 bolt is illegal.
but....................
im sure most inspection stations wouldnt notice. i dont know all the facts on the 6bolt, but its just a different block right? as long as your ecu still is a 2g itll be fine.
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
  • Wanted wtb black 2g dashboard
    Looking to buy a 2g black dashboard. Located in southern california but willing to travel.
    • randizzle420
  • Wanted 1g Wtb: uncut 6 bolt crank
    6 bolt uncut crank
    • erikoberdorfer
  • For sale 1g Used 1991 Turbo Engine Control Harness, Auto, with ABS
    Used engine control harness for a 1G turbo, automatic with ABS vehicle
    • 19Eclipse90
