Opinions on ECM link install
nek
832
9
Apr 17, 2009
Pittsburgh, Pennsylvania
So tomorrow Im going to buy my ecmlink v3 with gm maf setup included used. I will also be spending the day working with my buddy on his 1g at his house which is 1.5 hours away from my house. Do you guys think its ok for me to install my new setup while Im there or you think I should wait to get home. I obviously have no tuning experience and no experience with link so Im thinking I should probably wait but maybe you guys will think differently. Its not the install Im worried about its how the stock tuning will effect my ride home.
Thanks!
I would wait until you get home. Being an hour and a half a way if you can't get it to run right your stuck.
I had no problem driving my car 20 minutes after the install, so long as it was running properly before you install it I dont see why you would have a problem
I am assuming you profile is up to date.
K&N Filter - Ebay Intake - R&R Turbo Back Exhaust 3" - 1g Bov - Fmic Short 3.5" w/ core 2.5" pipes - 16G Ported inlet- -30 30 Mech Boost - Hallman Pro MBC - Ported 2g TB - 3in GM Maf
You are not running anything different than the stock set up besides the gm maf that will effect you ride. The only think that would change from the stock settings, ECMtuning can provide you with them, is the air sensor, you would have to change it from the stock 2g to the gm maf. After that go into the tps adjustment, get everything to the way you want it. (there are tutorials on the knowledge base at ECMtuning.com). When you are done you should be good to go as far as changing specs on ECMlink
You can pm me if you have more questions or need me to clarify what I said.
goodluck
  • For sale 4G63 Kiggly HLA
    Kiggly HLA $100 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 4G63 GSC Billet S3 Cams
    GSC Billet S3 Cams $400 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
