only way to get diff. mounts is to buy entire rear subframe?
mikeemike
May 7, 2004
rancho cucamonga, California
I have a 97 gsx. the rear differential has 3 mounts ,, one in the top front to maintain pinion angle,, which is available,, not the propblem. the problem is the two bushing that press into thne rear subframe and support the rear upper pumpkin. these prevent twist from occuring. I have tried to get the inserts from the dealer but they are available which the entire subframe,, which costs 600 dollars .. anybody know if inserts are available from any of the aftermarket companies ,, anyone ever experienced problem? the thing that dirrected my attention to this was the thud I would hear whenever I dumped the clutch at first I thought it was slop in the ring and pinion but that was not the problem. it was thbe mounts.help
