only boosting 7 psi not 10?
i think youre factory boost gague is just trippen a little, run a manuel boost gague right from youre throttle body to find out for sure what it is. and youre not running a Manuel Boost Controller? make sure youre boost/vaccume lines arent kinked, cracked, or tour. this should help, if not check the spring rate in youre wastegate. and when do you notice the difference in 7-10 psi? is it different when its hot or cold out??? different rpm levels? also check for shaftplay in youre turbo, a little up and down is ok/kinda normal. but in and out means its over and time for a new turbo or a rebuild. good luck.
Do you still have the factory BCS solenoid installed in your wastegate line? If so, you probably have big time knock issues, so the ECU is closing off the BCS, reducing the boost to save your motor from self-destructing. What octane are you running? Are you sure the base timing is at 5* BTDC where it belongs?
