older hks turbo timer
95gsttsi
132
Aug 20, 2010
Sturgis, Michigan
i just picked up an older hks turbo timer that came off a 1g. im not sure on the model number. but is there a wire diagram or will the 1g plug work with my 2g
2g color wires and location
12v - WHITE at Ignition Harness
IGNITION 1 - BLACK/WHITE at Ignition Harness
IGNITION 2 - BLUE/BLACK at Ignition Harness
ACCESSORY - BLUE at Ignition Harness
hks turbo timer colors
RED - 12v
GREEN - Ignition 1
YELLOW - Ignition 2
BLUE - Accessory
BLACK - GROUND
GREY - Parking Brake or Grounded
i believe its pin 86 that you want to hook up your speed wire too. Atleast that's what i did for my turbo timer.
You can use pin 58 at the ecu which is the engine ignition signal. Thats where the tachometer get the signal from.
