Okay is this a TD05 or TD06?
igorsgonemadd
46
Aug 10, 2003
Broken Arrow, Oregon
Ok guys i found a 20g for a good price and judging from the numbers on it I think it is a TD06 but im not sure. I want the TD06 not the 05. So here are the numbers on the turbo TD06H20G-TD0510CM2 I assume these are the numbers stamped on the turbo. He said he thinks it is a Td05. He said he found that description, where I dont know. The descrption in the add says hauns super 20G. I probably spelled it wrong though. Any help would be greatly appreciated. I need to know by tonight.
Thanks Igor
Only way to tell which turbine wheel you have is to measure it. vfaq has specs on TD05H and TD06 wheel measurements. Hahn Super 20G will have a 10cm housing on it, and the flange and opening will be square. All mitsubishi housings that bolt on to our cars will have a round hole, not a square one, like the HRC super 20G.
Thanks for the help guys I think im going to pass on it. I didnt realize it had a 10cm housing, im not an expert by any means but that just seems way way to big. Shouldnt it be like 7cm?
