TD05-TD06 Turbine Housing
mb3000
72
3
Aug 9, 2011
Myrtle Beach, South Carolina
Quick question, is the 3 bolt inlet flange for the turbine housing the same for TD05's & TD06?
I appreciate the response, but that's not what I asked. While most TD05+ turbos come with a 4 bolt flange, a select few, most probably from Greddy, have the 3 bolt triangular flange. My question was about the similarities/differences between the triangular flanges of TD05-TD06 turbos.
You can see the flange on the header in this picture. Top left.
My bet is you need to find a turbine housing with the correct flanges for your application. For us DSMers, most TD05 turbos (14b, 16g) have either 6 or 7cm housing, all with the DSM flange. The most common housing found on TD06 turbos is the T3 since the turbo is originally found in industrial applications. You might be able to find the 8cm DSM flange housing made by FP.
  • Wanted 6 bolt NT water pipe
    • chrisman287
