Demon33
- 296
- 2
- Aug 11, 2008
Southern,
California
I just got done installing a new rear main seal and I want to check it for any leaks. My feeling is that it should be ok , but I wanted everyone's opinions on this- is it ok to start the engine with just the flywheel bolted to the crankshaft and without the clutch or transmission installed?
but i thing you might be able to start the engine fine without the tranny or clucth. just make sure you engine mounds are tighten.
You guys are right about the starter. That part slipped my mind. I guess I'll have to bolt everything back up and maybe use the flywheel inspection area (sheet metal cover) at the bottom of the tranny to check for rear main seal leaks.
