ok to run without tune?
mistagst
168
May 1, 2009
Elgin, Illinois
my car is basically stock only mods are air intake and catback exhaust at the moment i have a intercooler piping kit for the stock t25 with 1g bov. would this be ok to install and run without some sort of tune? thanks
Yep you will be just fine. You could even up the boost a little if you wanted to. But a wideband and a logger would be a good investment right about now. That way you know exactly where your at.
You don't need a Tune with what you have, you can boost up a little with out a problem, if you get bigger injectors, then you need to have it tune, however adding just a bigger turbo you will only need a Widebad to monitor were your full is at.
You are good at this point, don't need to do anything.
