OK. Take a look at these pics. Inside my wheel well. Wisemen help please!
BoostInsideTSi
200
May 5, 2004
Aurora, Illinois
Here are 2 pics from inside my wheel well:
Holy SHIT re-size those things.
No bigger than 500 wide.
The peice with the yellow on it is being pushed down by the top of the fender wall. What would cause this? The only thing I have changed in my suspension is the camber kits on the upper control arm.
I have a weird clunking when breaking and turning a lot, and after searching forums a bad Balljoint is a popular reason why. Could this be the problem? How do I fix this? Also in the other pic, it shows my bent lower control arm (hit a curb) Gonna put a new one on. Does everything else in the pic look OK?
Thanks.
Mike
hi,
well i'm no "wiseman", but the bend tip if the upper arms is normal with camber kit instalation. Mine did the same after i installed my Ingalls camber kit. They are known to have small clearance problems....
Also if you camber kits is Ingalls it seem u got them installed backwards...
Also to check if you ball joint is bad. Jask up the can and grab the top of the wheel and see if you can move it in ot out....
halik
