Oil squirters
98mitsubishigst
1,526
16
Nov 17, 2008
Pittsburgh, Pennsylvania
Well, I need a Quick answer before i bolt my Oil pan back on..
and call if done for my engine and ready to go back in my eclipse..
I have a 97 Mitsubishi Spyder Eclipse Gst.
Stock Rebuild. and NEVER did i once take out my oil squirters that people are explaining to me that i have.. (the hook looking ones that look like this..
Heres pictures of where they should be .. correct? Let me know if i got them or not... please i want to start putting her back in the engine bay.
is no1 really going to answer me?
i neeedd to know..
do you have holes in the oil galley for them.... I do not see any..... so it looks to be a NA block
Did you rebuild your motor, or did you buy a different block to rebuild? Cause N/A blocks don't have oil squirters, which could be a problem if you are using stock cast pistons. If you had built it using forged pistons then it's not as important to have them.
Also I've never worked on a 2G block but shouldn't it have this style squirter?http://www.extremepsi.com/store/customer/product.php?productid=21523&cat=971&page=1
In which case I'm not sure where they are located.
If its is a 6 bolt turbo block, then you will have oil squirters like the ones you have in your picture. However, If it is a 2g block, then it will have oil squirters, but they will not look anything like the ones you have. I am at work right now so I can't get you a picture, but if I recall correctly, you can't see 7bolt oil squirters unless you have the pistons out as they are hidden pretty well. If you feel around the bottom of the cyliners, you should be able to find them. Also, there is no need to remove them.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
