Oil return on pan side ?
Jeff@Slowboy
206
Jan 1, 2004
indiana, Pennsylvania
I have the slowboy g50 turbo and was installing the oil return. On the pan side where u bold one of the fittings to the pan. One bolt hole is stripped cuasing an oil leak. I was wondering what the best way to fix this is so it will stop leaking.
jeffb006 said:
does anyone know what tap i should use
Bring the bolt with you to the hardware store, I believe it's M6 x 1.00 but it's been a while so I'm not 100% sure.
I can retap it the same size i dont have to go bigger?
Try chasing the threads with the same size tap first, if that doesn't work, remove the pan and retap for m8 x 1.25.
I thought it was M6x1.25
Like I said, I'm not 100% sure, he should still bring the bolt to the store.
K thanks for the help I will try this tom. before work. when removing the pan do i just have to take the downpipe off or does it require more.
Read your service manual. For 1G's, we have to remove one of the cross members as well as the transfer case.
Those who've stripped the return flange capscrews usually go to 1/4-20 threads and bolts. If you use grease on the tap and take short cuts, the grease will trap all the chips.
