Oil return lines. I need help!!
coryd21
91
Jun 21, 2009
Paragould, Arkansas
I am using 8 A N fittings for my oil return and the hose is 8 A N, and when i get on it im getting what im guessing is an oil blow back in my exhaust. When i get on it you can see oil come out my exhaust. How can i fix this problem???
are you talking about oil splatter coming out of your exhaust? or smoke.. also take off your intake and check the turbo housing and hot pipe for oil. its easy enough to do and one more thing to check of the thats not it list.
well about 6 months ago i sucked up some water from a bed rain. I didn't have the turbo kit on then it was just the high flow intake and cold air intake that ran really low. Too low apparently, so I immediately went and got new plugs and wires just to make sure I didn't burn any out and when I took out the number 1 and 3 they both had some oil on them. I did some research and was told that it could be my valve guilds, So is it possible now that i have the turbo on there and its running boost now that it could just be pushing the oil out faster and making it look like the turbo is leaking??
