oil return line and head gasket question
The difference between the return lines is the 2g return line is designed for the garrett oil return pattern, large spacing in between the bolts, and the 1g line is designed for the Mitsubishi return pattern, small spacing in between the bolts.
Oem hg just have it decked and the head, a ss oil feed or aftermarket?
EXTREME PSI : Your #1 Source for In Stock Performance Parts
return line is different
yeah, the head is being milled,and i bought a OEM headgasket from mitsu dealer
--if im using a OEM headgasket does it matter what thickness it is after getting the head milled?
How much was milled off the head?
http://www.dsmtuners.com/forums/cyl...how-measure-4g63-cylinder-head-thickness.html
What OEM head gasket are you going to use ?
Composite?
MLS?
How was your head milled?
http://www.dsmtuners.com/forums/cyl...0613-why-not-let-your-head-belt-surfaced.html
http://www.dsmtuners.com/forums/new...face-4g63t-cylinder-head-mls-head-gasket.html
