Oil Quantity
dmc67
290
3
Oct 17, 2004
Middlebourne, West Virginia
I'm about to do an Oil change in my car and cant find out how much Oil it takes. So my question is how much does it take? I am thinking 4 1/2 quarts.
if you dont know how much it takes you could always put some in, pull dip stick out and check it, add accordingly. also after changing, wouldnt be a bad idea to start the car up (make sure you have oil pressure) let the car run a little, shut it back off, let it sit awhile, then RE check the oil and add accordingly.
TalonNYC said:
Hayne's manual states 3 Quarts of Oil should be added.
That would be wrong. The FSM says 4.6 quarts including filter and that the filter holds a half quart for a 2.0L. So without a filter it would be a little over 4 quarts. The 1.8L holds a half quart less.
Steve
