samhain
- 0
- Jul 31, 2008
Lincoln,
Nebraska
OK I have been battling this for awhile now. I bought a rebuilt motor off of craigslist.
1990 Talon TSi AWD
Installing the motor went fine. I primed the oil pump before installing the T-belt had oil all the way up to the turbo connection @ the head. Right off the bat the car has low oil pressure both sending units confirm this idiot light blinking and pressure gauge very low. I can look in the valve cover and see oil squirting onto the cams so I am getting some oil. Also have valve clatter a little. Increasing the rpm's doesnt really raise the pressure at all. I did drive it around the block and it runs great. Tore it apart again thinking they forgot to block the oiling holes for the balance shafts but all was good bearings were installed with no holes at all. The oil pump itself is pretty hard to turn especially considering there is no longer a balance shaft hooked up to it. I am wondering if there could be something wrong with the oil pump to where it is just weak and not making good pressure?
1990 Talon TSi AWD
