oil pump
Low. Oil. Pressure. -> Bearings -> Siezed motor. With a DSM, I find it is a necessity to have an AFTERMARKET oil pressure gauges.
Leaking oil out of the timing belt cover is a sign. Oil on the belt, etc. What are you seeing/hearing/feeling....tasting?
I see... The stock pressure gauge is garbage. People are going to tell you to get an aftermarket one, especially if you have any mods done.
My stock gauge will read "0" at warm idle and just above the first notch at 60 mph, or ~2800 rpms.
Aftermarket read 20 psi idle and 60-70psi at the same rpms.
You can buy one from your local auto parts store, and just for the purpose of testing your oil pressure there's a small plug in the left hand side of your cylinder head. Its 1/8 NPT, buy an oil pressure gauge with this fitting and thread it in this hole to check it against the factory specs.
