oil pump
purpleslut
Jan 8, 2013
lititz, Pennsylvania
I posted a thread a few weeks ago about a oil pump gor a hyundai block i ran the vin on the motorad nothing is pulling up i ordered multiple oil pumps for different years the issue im having is the 6bolt oil pump fits but i can bolt it up bc so.e of the wholes are off set some so im not sure if maybe a 7 bolt oil pump would work or if anyone ever ran this block or what i need tk di any help would be appreciated
Please start by using acceptable grammar. This whole post was very hard to read and made little sense.
In addition to that it would help if you told us what exactly what hyundai block you have.
If you are having trouble with 6 bolt oil pumps then check the crank and count the number of flywheel bolts, if in fact you do have 7.... DING DING DING, you found your problem!
If i knew which hyundai block i had i wouldnt be in the situation now would i and its a 6 bolt crank ding ding ding but guess what the 6 bolt oil pump bolt wholes do not line up which is why i made the post can ypu read this one
Ok you will probably need a 95-96 oil pump. Even tho it is a 6 bolt. On the Hyundai blocks they used 6bolts but they had can and crank angle sensors so you will probably need a 7bolt oil pump.
