oil pump sproket turns but wont come off
boosted86
414
5
Sep 7, 2005
Weston, Florida
ok, well ive had this little oil leak for quite some time now, so i decided to fix it to day. the leak was coming from the front of the motor(t-belt side) so i took off my timming cover and saw that i was leaking from the tensioner bolts, and the oil sproket, i atempted to remove the sprocket with no luck. i used a vice script to hold it in place and a 14mm socket to turn the nut, well the nut turned(kinda loose) but it will not come off, it will just spin and spin on the gear bolt.:mad: i dont understand why its doing this. also i have my b/s eliminated. thanks in advance!!!
    • george bromwell
    • pma1123
    • Sdcryan1
