Oil pressure sensor removal
Drews99rs
41
Jun 2, 2008
Dallastown, Pennsylvania
Ok so I'm having a problem removing the green clip from the oil pressure sensor on the 420a, It has a red slider on top that can slide back and fourth but no matter which way I slide it I can't figure out how t actually get it to come off. Any input would be appreciated, Thanks!
If i remember correctly you should slide the red piece to the side and push the tap in, sometimes the tap gets dirt and junk under it and it makes it a pain to push in. spray it with some pb blaster and try to very carefully squeeze the tap with a pair of pliers to get to off
well it depend how you put it back on for the first time and now you want to take it out. You can feel one end have big lip and other end is flat so you can know where to pull it to take it out.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
